Issue with Reading Life Safety Points from Siemens Cerberus FC924 on AS-P (3.2) via BACnet IP
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
  • Support
  • Issue with Reading Life Safety Points from Siemens Cerberus FC924 on AS-P (3.2) via BACnet IP
CraigEl
Administrator CraigEl Administrator
35
chris_clerc
Administrator chris_clerc Administrator
8
MikaelKrantz
Guinan MikaelKrantz Guinan
7
Back to Ask the Community
vihanger
Ensign vihanger
Ensign
Posted: ‎2024-12-09 10:27 PM
1447
I am trying to connect a Siemens Cerberus FC924 fire panel to a Schneider AS-P controller running firmware version 3.2 through BACnet IP. The panel is successfully online, and I can see the points, but they are presented as Life Safety Points instead of the expected Analog Inputs (AI) or Binary Inputs (BI).
The issue is that the AS-P does not seem to read any changes in these points. However, when I connected the fire panel to a computer and monitored the values through Yabe, it showed the value changes. I have added a screen record of Yabe and AS-P here.
Has anyone encountered a similar issue? Does the AS-P support Life Safety Points, or is there a workaround to map these points as standard AI/BI objects? Any advice or guidance would be greatly appreciated!
  • Others & accessories
Fendour
Lieutenant | EcoXpert Master Fendour Lieutenant | EcoXpert Master
Posted: ‎2025-01-24 01:06 AM
Dear Vihanger,
Currently the BACnet Life Safety objects aren't yet supported in EBO product lines.
See below link:
https://community.se.com/t5/Building-Automation-Knowledge/Unable-to-see-Life-Safety-objects-from-Fir...
Replies 4
janim
Spock janim Spock
Spock
Posted: ‎2024-12-12 10:26 PM
Are you try to renew subscriptions.
Yabe is polling. Try use COV. EBO use primally COV.
If COV is not working with Siemens then use this guide
BACnet blacklist implementation to disable features in an EBO Server BACnet interface. - Schneider E...
If it ain't broke, don't fix it.
Fendour
Dear Vihanger,
See below link:
vihanger
Ensign vihanger
Ensign
Posted: ‎2025-09-29 04:15 AM
1
834
Thank you all for your replies. I had to use a separate gateway between the Fire Panel and the BMS to convert the Life Safety Points into BACnet digital points.
Robin_nguyen
Ensign Robin_nguyen Ensign
Ensign
Posted: ‎2025-11-13 07:07 PM
In response to vihanger
Hi Vihanger, May I know what separate gateway being used? Like model number, and brand.
