Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
Posted: 2023-02-16 05:33 AM
I'm trying to figure out how to configure a Connexium TCSESM163. I know it's now obsolete but I seem to be hitting the wall that is enabling Java in 2023.
Windows 10 VM
I've installed the Ethernet Switch Configurator 2303. Used DHCP to assign an address to the new switch that I have. Successfully pinged the switch from the VM. Run the tool and it finds nothing. There are three network adaptors but choosing any of them has no effect. Tried to access the GUI through various browsers but no joy as it's Java. Tried disabling the firewall. Tried enabling McAfee Timed groups (I'm in an SE IT environment) in order to lower the firewall on the host. No joy.
Windows 7 32 bit VM (freshly created)
I've installed the Ethernet Switch Configurator 2207x86. Used DHCP to assign an address to the new switch that I have. Successfully pinged the switch from the VM. Run the tool and it finds nothing. There are three network adaptors but choosing any of them has no effect. Tried to access the GUI through IE but no joy as Java doesn't want to enable (been through many IE enables).
Do I really have to use Telnet?? Any tips?
Posted: 2023-06-11 07:26 PM
Where I can find to Download the 2303? I wish there is new revision support windows 10 and windows 11.
I saw below Link may help you. use Internet Explorer 11 with Java v8 runtime 281. This was also all inside of a WIN7 VM.
Solved: Ethernet Switch Configurator Program (2.3.03) - Communities (se.com)
