AS offline icon appear
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
  • Support
  • AS offline icon appear
CraigEl
Administrator CraigEl Administrator
35
MikaelKrantz
Kirk MikaelKrantz Kirk
7
Omaelk
Janeway Omaelk
3
chris_clerc
Administrator chris_clerc Administrator
2
Back to Ask the Community
Posted: ‎2019-08-21 10:41 AM . Last Modified: ‎2020-12-02 04:30 AM
3
4107
I am facing an issue on my AS. I am restoring my ES, which was successfully restored but my AS appear to be offline.
I notice at Device Administrator the it indicate "wrong logon" . I put the logon password, which is the same as workstation password.
I was also facing problem to communicate my AS thru LAN cable at Device Administrator.
Connecting using USB was ok & i could ping my AS thru LAN.
Please see attached pictures.
Really appreciate your help.
  • ecostruxure building operation
Omaelk
Janeway Omaelk
Janeway
Posted: ‎2019-08-29 07:27 AM . Last Modified: ‎2022-10-19 02:47 AM
Hello @nizar_iannai_co , check this link: https://community.se.com/t5/Knowledge-Base/Planning-for-Continuum-LAN-Upgrade/ta-p/8105
If it's not helping, I add @AdamSteele to this thread, he should be able to help you!
PS: do not hesitate to check the Knowledge base & use the global search bar to see if your issue was already raised before
ikechukwum_bass
Lieutenant ikechukwum_bass
Lieutenant
Posted: ‎2022-09-07 04:07 AM
1883
Hi Nizar, i am having similar issue. did you later get help?
Omaelk
Janeway Omaelk
Janeway
Posted: ‎2022-09-09 05:02 AM
In response to ikechukwum_bass
Hello @ikechukwum_bass , as an Building & Residential Partner EcoXpert, you have access to the private community EcoStruxure Building Operation. I invite you to post your issue here to get support from our experts.
Thank you
Oma
Community Management Team
