Plant Scada Studio 2020 Digitals
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • Plant Scada Studio 2020 Digitals
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
Back to AVEVA Plant SCADA Forum
Steve00
Steve00
Cadet
Posted: ‎2022-11-03 03:08 AM
1752
Hello everyone,
Hopefully there is some that can point me in the right direction.
I am developing a Standalone project with a single IO device being a Compact Logix PLC.
I have communications up and running with all INT's DINT's and arrays and this seems to work fine.
The issue I am having is with Digitals. The Runtime does not read or write to digitals. I have tried a single digital thinking there was a problem with data structures but still doesn't work. The runtime can change values in the PLC animate anything as long as it is not Digital IE a Bool. Runtime seems to read the digitals (not BAD) but variable doesn't change either by Runtime or manipulating in the PLC code. The Bools just stay as a zero. Is this something anyone else has experienced or and I missing the obvious.
Thanks in advance
  • Plant SCADA Studio
stuartm
Ensign stuartm
Ensign
Posted: ‎2022-11-03 04:43 AM
1740
Hi Steve,
Versions of the ABCLX driver prior to 5.00.04.000 had this problem.  I suggest you check this and if necessary, update to the latest version.
Regards
stuartm
Ensign stuartm
Ensign
1741
Hi Steve,
Regards
Steve00
Steve00
Cadet
Posted: ‎2022-11-03 02:42 PM
In response to stuartm
Updated driver and works fine. Thanks for that much appreciated. Sometimes we just need a little prompt.
