what is the charging voltage of APC SURTD3000XLI SYSTEM. i am getting it 220volts in my system but showing battry fault and tripping
  • what is the charging voltage of APC SURTD3000XLI SYSTEM. i am getting it 220volts in my system but showing battry fault and t...
2151
119
83
Posted: ‎2021-06-29 08:00 PM . Last Modified: ‎2024-03-21 01:17 AM
867
what is the charging voltage of APC SURTD3000XLI SYSTEM. i am getting it 220volts in my system but showing battry fault and tripping. so i have chacked it on another set of battries with different make but no solution found plaese suggest me a solution
Posted: ‎2021-06-29 08:00 PM . Last Modified: ‎2024-03-21 01:16 AM
charger for ups is 220 VA,
check battery charge for each drawers if its in range 100 VA
Hi...you can charge battery for 8 hours, maybe battery unloaded. remember two sets battery must charged, do not on panel UPS only wire until charged
it may be helpful if you can provide and attach the log files (event.txt, data.txt, config.ini) from your UPS network management card so we can see what is going on. instructions on doing that are in the knowledge base -> http://www.apc.com/site/support/index.cfm/faq/ and search for article FA156131
