84570members
353841posts
what is the charging voltage of APC SURTD3000XLI SYSTEM. i am getting it 220volts in my system but showing battry fault and tripping
umesh1989_apc
140
This was originally posted on APC forums on 4/4/2013
what is the charging voltage of APC SURTD3000XLI SYSTEM. i am getting it 220volts in my system but showing battry fault and tripping. so i have chacked it on another set of battries with different make but no solution found plaese suggest me a solution
nael_apc
Re: what is the charging voltage of APC SURTD3000XLI SYSTEM. i am getting it 220volts in my system but showing battry fault and tripping
This was originally posted on APC forums on 4/11/2013
charger for ups is 220 VA,
check battery charge for each drawers if its in range 100 VA
3 Replies 3
This reply was originally posted by NGE on APC forums on 4/4/2013
Hi...you can charge battery for 8 hours, maybe battery unloaded. remember two sets battery must charged, do not on panel UPS only wire until charged
This reply was originally posted by Angela on APC forums on 4/4/2013
it may be helpful if you can provide and attach the log files (event.txt, data.txt, config.ini) from your UPS network management card so we can see what is going on. instructions on doing that are in the knowledge base -> http://www.apc.com/site/support/index.cfm/faq/ and search for article FA156131
nael_apc
