can i still use?
  • can i still use?
2151
119
83
Posted: ‎2021-06-29 09:40 AM . Last Modified: ‎2024-03-21 04:05 AM
1247
can i still use?
i got the APC BACK UPS XS 1300 from a friend turns on and works fine but the battery is not charging at all as soon as i plugged it the first time showd it was charging but then nothing....can i still use it even though the battery is not charged up? more interested in the surge part!
thanks
Posted: ‎2021-06-29 09:41 AM . Last Modified: ‎2024-03-21 04:05 AM
The unit was made October 10, 2006, if the battery has never been replaced, just replace the battery and the unit should be as good as new!
Replies 5
Try installing the Apc Powerchute Software On A Computer If You Have A Usb Cable:
http://www.apc.com/products/resource/include/techspec_index.cfm?base_sku=SFPCPE302
Also What Is The Exact Model And Serial Number On The Unit?
is there a Mac version of Powerchute?!?!
these are the only numbers that i got from the UPS
BX1300LCD
JB0641019870
Also, yes you can still use the surge part, but i would recommend removing the battery, bad things tend to happen when you charge a bad battery for an extended period of time, if the unit chirps because its removed, just simply mute it.
Good Luck,
Wwallender
thank you very much i guess i should start paying more attentino on the stuff i bring home i wll change the batt thanx
