can I use ethernet to wire pc to ns1050?
  • can I use ethernet to wire pc to ns1050?
2151
119
83
Posted: ‎2021-06-28 09:30 PM . Last Modified: ‎2024-03-26 12:25 AM
643
I received a connection cord with ns1050 that has USB to ethernet. Thought i could extend distance using cat 5 ethernet but when I installed PowerChute Personal Edition the software could not find ups. Is the cat 5 not compatible with supplied cord? If so what type cable can be used to extend communication?
The cable has a special proprietary pinout on it even though it uses an RJ-45 ethernet connector. Even though technically APC doesn't recommend it, you might try extending it on the other end, maybe using a USB hub to give you a little extra cable to work with. You might encounter problems with that though it if the hub isnt externally powered and you have a lot of devices plugged into it.
