back-ups rs 600 br 600ci
  • back-ups rs 600 br 600ci
2151
Spock Teken
83
Posted: ‎2021-06-28 04:16 AM . Last Modified: ‎2024-03-27 01:53 AM
898
When i switched on the ups yesterday the ups switched on regularly there after it suddenly stopped flashing and since then it is not supplying power and im not able to switch it off using power button Pls help
The UPS will not power on if the battery is disconnected so you should verify both the hot and neutral leads are secure. If the battery is connected properly check to see if the battery has the proper charge. A good battery should have a charge around 13.5v DC. If the charge is low the UPS will not power up.
Replies 6
Reset the Back-UPS
1: Disconnect any attached load.
2: Unplug the UPS from the wall socket.
3: Disconnect the UPS' internal battery.
4: Push and hold the "On" button on the UPS for 5 seconds
5: Reconnect internal battery.
6: Plug UPS in to known good power source.
7: Turn UPS on.
If that does not resolve the issue contact local support for assistance.
thanks for answering bill i will try it  and reply if it works or not.
when i press the on button after disconecting i get a long beep then shud i press the button again
No. Once you hear the beep you release the button and the UPS is reset. The beep should be short since the UPS is unplugged for AC source and the battery is disconnected.
  1. now its not even switching on pls help me. is it it of no use now? i connected everything prperly
