Will UPS run on True Sine Wave Power Inverter
  • Will UPS run on True Sine Wave Power Inverter
2151
119
Posted: ‎2021-06-28 08:51 PM . Last Modified: ‎2024-03-26 12:57 AM
725
Can anyone tell me if a BE750BB UPS will run on a 300 Watt True Sine wave Inverter.
The load we have on it is about 50 watts. What I am unsure of is the charger load. I could not find docs anywhere on Input amperage.
Here is a link to the inverter I want to use. Will this work?
[http://www.outsidesupply.com/index.asp?PageAction=VIEWPROD&ProdID=78&HS=1|http://www.outsidesupply.com/index.asp?PageAction=VIEWPROD&ProdID=78&HS=1]
EZ_Button_apc
Commander EZ_Button_apc
Commander
Sure why not... as long as the power is clean and it has valid wiring (hot, neutral, ground). The UPS itself will draw very minimal power, so the load will all depend on what you attach to the UPS. That along w/ the UPS can't exceed the 300 watts.
450 Watts, no? That's the rating on the 750.
EZ_Button_apc
Commander
