Which APC UPS is compatible with the Battery Packs???
Select a Country
  • Which APC UPS is compatible with the Battery Packs???
BillP Leader
2150
147
83
Posted: ‎2021-06-29 09:59 PM . Last Modified: ‎2024-03-20 03:25 AM
3856
I recently purchased two APC Battery Packs expansion packs for my BackUPS Pro 1400 and I notice the connectors on the BackUPS Pro 1400 and the expansion packs are slightly different.
Which APC UPS can you recommend me that has the correct plug for these expansion packs. I don't care if they're discontinued. I can always find it on ebay.
Thanks in Advance.
  • apc
  • backups
  • battery
  • compatiblity
  • pack
BillP Leader
Leader
I don't know of one we make for this particular application but there may be information out there or if anyone wants to chime in and provide information to use at your own risk.
The only adapters I know of are to make different Smart-UPS Battery Packs work with other generations of Smart-UPS UPS models i.e. using an SU battery pack with an SUA Smart-UPS (like what is suggested here -> Using an SU48R3XLBP with an SUA3000RMXL3U | FAQs | Schneider Electric US)
Replies 5
BillP Leader
Leader
To double check compatibility, could you provide the exact model of your Back UPS 1400 from the white sticker on the back or bottom and the same for the expansion battery packs you purchased?
Thanks!
The main APC UPS is a BP1400.
The APC battery packs are SU24XLBP
BillP Leader
Leader
OK, thanks. That is a Smart UPS external battery pack for older units. I found this documentation -> How do I select the correct Smart-UPS XL battery pack? | FAQs | US
Is there an adapter cable available that will work for the BP1400 and the battery packs???
BillP Leader
Leader
