Warning State: Battery Temperature Sensor on Rack Mount Smart-UPS 3000 VA
  • Warning State: Battery Temperature Sensor on Rack Mount Smart-UPS 3000 VA
2151
116
83
Posted: ‎2021-06-28 07:15 AM . Last Modified: ‎2024-03-26 10:37 PM
1291
I just installed a new UPS and I getting a beep every 3-4 seconds. Self test will not run and I seeing Warning State: Battery Temperature Sensor
Hi Hugh,
To help in identifying the source of the issue, can you please provide the exact model number / serial number of the unit and the number of extended run battery packs you are using, if any?
You've indicated the configuration is newly installed, can you provide a time line as to time in service? Is the device being used in an open data center or in a structured wiring closet? What method of cooling have you implemented? If you have a Network Management Card installed, can you provide a copy of your Data log for review?
Secret Squirrel
Hi Hugh,
Secret Squirrel
