UPSCAPO will not run after install
  • UPSCAPO will not run after install
2151
123
Tranas
Tranas
Cadet
Posted: ‎2025-04-08 04:27 AM
575
Windows 11 24H2 fully updated
UPSCAPO-Management Software downloaded from APC website
.NET 3.51 enabled and updated in Windows 11
Software completes installation, but when run, throws this error message:
Unhandled exception has occurred in your application...
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.FormatException: Input string was not in a correct format.
   at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
   at System.Number.ParseDouble(String value, NumberStyles options, NumberFormatInfo numfmt)
   at System.Double.Parse(String s, NumberStyles style, NumberFormatInfo info)
   at System.Convert.ToDouble(String value)
   at UserInterface.Form1.timer1_Tick(Object sender, EventArgs e)
   at System.Windows.Forms.Timer.OnTick(EventArgs e)
   at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.9179 (WinRelRS6.050727-9100)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
UserInterface
    Assembly Version: 3.2.3.0
    Win32 Version: 3.2.3.0
    CodeBase: file:///C:/Program%20Files%20(x86)/UPSCAPO/UserInterface.exe
System.ServiceProcess
    Win32 Version: 2.0.50727.9157 (WinRelRS6.050727-9100)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.ServiceProcess/2.0.0.0__b03f5f7f11d50a3a/System.ServiceProcess.dll
System
    Win32 Version: 2.0.50727.9176 (WinRelRS6.050727-9100)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Data
    CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Transactions
    CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll
System.EnterpriseServices
    CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.EnterpriseServices/2.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Possibly some configuration issue is at fault? Help would be appreciated.
TIA
  • Home & Office - UPS & Software
Kirk
Posted: ‎2025-04-08 07:55 AM
558
The release notes don’t say Windows 11 is supported. I suggest you reach out to APC Technical Support to see if a new version is coming.
Questions Ask . . . 👍
Tranas
Tranas
Cadet
Posted: ‎2025-04-08 09:30 AM
In response to Teken
LOL ... Thanks. APC is really on the ball. I will give that a shot, but expect little joy.
"Windows 11 is the latest major release of Microsoft's Windows NT operating system, released on October 5, 2021 as the successor to Windows 10"
