How Can I Connect Back-UPS 1500 to home network
  • How Can I Connect Back-UPS 1500 to home network
2151
123
JBNC12345
JBNC12345
Cadet
Posted: ‎2025-04-02 12:35 PM
1025
I have a Back-UPS 1500 model that uses PowerChute Serial Shutdown with a USB direct connection to PC.
Is there a way I can connect this UPS to a LAN home network to make config changes and monitor via WIFI without having to take a laptop up near it and attach the USB cable to login? For example, is there a USB to Ethernet port adapter that would do this?
  • Home & Office - UPS & Software
Replies 4
Kirk
Posted: ‎2025-04-03 04:43 AM
1010
Not exactly sure what you’re trying to achieve here?!? The intent of PCSS is to gracefully shutdown a computer system that is backed up by a UPS.
If all you want to do is see and monitor the UPS remotely than you can install APCUPSD / NUT software on a Raspberry Pi.
Going this route is low cost, low power, and provides remote access. Other alternatives is to simply allow remote access to a connected computer system and configure network sharing.
If you require WAN offsite access than any VPN can be installed, configured, and used for a more secure connection from the outside.
Dozens of options for you to choose from and simply requires sweat equity in terms of research, configuration, and deployment! ☝️
Questions Ask . . . 👍
JBNC12345
JBNC12345
Cadet
Posted: ‎2025-04-03 11:29 AM
In response to Teken
As said in original post, I want to be able to connect to PowerChute and the UPS without taking my laptop up to the UPS (which is in a very hard to reach area/dormer) and plugging in the USB cable.
Can I just convert the USB cable to a network port than connect to my switch? So 1) how do I physically get it connected to my home network, and 2) what are the steps to access PowerChute from another device on home WIFI network?
JBNC12345
JBNC12345
Cadet
Posted: ‎2025-04-08 05:30 AM
918
Teken,
Don't have a Pi, but I found an old Odroid C1+ box that I could use for UPS monitoring. Do you know how I would set it up? What OS to load for APCUPSD / NUT to run? What version of APCUPSD / NUT?
Kirk
Posted: ‎2025-04-08 07:49 AM
In response to JBNC12345
I would refer you to the following resource guides as they outline all of the requirements:
https://wiki.debian.org/apcupsd
https://networkupstools.org
Questions Ask - If not, and this provided the answer please do mark it as a solution. So it may help the next person asking the same . . 👍
