Dear Community Members,
We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience.
SE Community Team!
Shutdown % values
  • Shutdown % values
2151
Spock Teken
109
83
Posted: ‎2021-06-28 07:07 AM . Last Modified: ‎2024-03-26 10:44 PM
432
Shutdown % values
Hello there, new to APC and UPS generally, and have recently bought a 1400va BX1400U unit which appeas to work well, as mine is only powering a basic pc/router and 3 12v IP cams, I do get a good runtime from the unit on battery as the drain is only around 40w or so.
I did notice a couple of things. When doing some runtime tests with powerchute, I wanted to see just how long the perjpherals would run on battery. Sadly the first time I did the test I had to manually power down the unit as I had to go out, Powerchute correctly showed as 1 blackout of 11 mins on battery, which was about right
When I got home I retested it with 100% charged battery and managed over 2 hours of runtime. I noticed tho that the unit shut down itself at 7% charge still remaining and that powerchute had correctly recorded a 2nd "blackout" but instead of showing the 2 hrs plus runtime on battery, it still shows 11 mins total.
Just wondering why the unit shut down at 7% and why Powerchute still only shows 11 mins as time on Battery?
Many thanks,
Chris Morgan
Posted: ‎2021-06-28 07:08 AM . Last Modified: ‎2024-03-26 10:44 PM
It tries not to run the batteries total dead, not sure if the 7% is about 2mins. of run time.
