Back-UPS BE700G-GR Sensitivity & Power Capacity Questions
Send InviteCancel
Posted: 2021-06-2807:07 AM. Last Modified: 2024-03-2610:44 PM
Hello, I have this model stated in the title - Back-UPS BE700G-GR - and I'd like to know two things:
- On the product overview it's mentioned that it has adjustable voltage sensitivity, but in the Manual I don't see anything regarding this. How exactly does it work ? How is it adjusted ?
- This may be a dumb question, but nevertheless: the max. Power Capacity of this model is 405W, so then if I plug-in my PC which is running on a 750W PSU to the Battery Back-Up outlet would there be a problem ? Can either the PC or UPS be damaged ?
Thanks !
APC Power-Saving Back-UPS ES 8 Outlet 700VA 230V CEE 7/7
