SMC1500 Do I need a Firmware Update?
Select a Country
  • SMC1500 Do I need a Firmware Update?
BillP Leader
2150
144
Techie_apc
Techie_apc
83
jcahow
jcahow
Explorer
Posted: ‎2024-11-07 01:54 AM
4183
Recently picked up an used SMC1500 Smart-UPS that looks like new.  I put new batteries in it and it is working fine.
I am unclear whether this specific model requires Firmware updates.
I downloaded the Firmware Update Wizard and it says the current Firmware is UPS 10.0 and it can be upgraded.
The Firmware Upgrade Wizard shows this information
UPS 10.0
MCU 03.0
UBL 01.4
MBL 03.0
I could not figure out the UPS ID number for this specific SMC1500 model.
Could someone tell me if this device is on the latest Firmware and if not which Firmware file I need to download to bring it up to date?
  • Home & Office - UPS & Software
Replies 10
Champion
Posted: ‎2024-11-07 04:31 AM
Firmware updates on any APC UPS is extremely dangerous as such APC does not recommend doing so unless guided by APC Technical Support live over the phone when the hardware is under warranty.
Firmware should be applied and considered if it addresses a security, bug, or feature enhancement.
If the hardware is (NOT) in warranty you have a better than 50% chance of bricking a completely operational system! ☝️
Given you have no idea the age or operational history of this unit the odds of a failure is extremely high.
You can scan this forum to see the thousands of threads about failed upgrades! 🤦‍♂️
Regardless, if you would like to pursue this further please read and fully understand all the requirements and have on hand (EVERYTHING) that’s called out for positive outcome.
APC Firmware FAQ:
https://www.apc.com/us/en/faqs/FA279197/
UPS ID:
https://youtu.be/cPTzPPCTU7k?si=3d29F9FI98R_SVOW
The UPS ID can also be found if you have a NMC under the About UPS. It can also be found if APC PCBE / PCSS software is connected to the UPS. 👍
jcahow
jcahow
Explorer
Posted: ‎2024-11-07 09:46 PM
4134
Thanks for taking the time to reply and for the warning about APC firmware upgrades.  I am a long time computer user and worked in IT for decades before retiring.  I must have performed hundreds of firmware updates over the years on different devices and never bricked anything yet (always a first time).  I can see why APC's firmware updates are so problematic based on their confusing process.
That being said I would pass on these comments based on what you wrote me.
I had already read both of the FAQs you mentioned.  The first FAQ is very confusing and I can see why someone in support should probably walk you through the firmware update process.
I am still unclear if there is even a firmware upgrade available for my specific SMC1500 UPS from 2017.
If there is I would not even try to apply it until I learned more about what it pertained too.....
The second FAQ on the UPS ID is worthless to me as it describes a different UPS layout and uses buttons that do not even appear on my UPS.  My SMC1500 only has Two buttons under the LED screen and not Four as shown in the video.  There is no way to access the UPS ID directly from the UPS.  My SMC1500 was produced in the 31st week of 2017 so maybe the video only applies to newer model SmC1500 devices.
I am using PowerChute Serial Shutdown which does show quite bit of information about the UPS.  It shows the production date of 2017 as well (as compared to getting it from the actual Serial Number).
I could NOT locate a UPS ID shown anywhere in the Serial Shutdown data contrary to what you mentioned.
Could you specifically mention how to access the UPS ID from the Serial Shutdown software in case I missed it?
I
Champion
Posted: ‎2024-11-08 08:37 AM
In response to jcahow
Please show me all the available tabs in PCSS. You may install PCBE software as I know the UPS ID is stated there.
In the LCD Menu is there no About page on this system?!?
NOTE: When you first install the APC PCBE software the USB Driver will quickly display the UPS ID on the screen.
jcahow
jcahow
Explorer
Posted: ‎2024-11-08 09:07 PM
There are only two buttons under the LED screen and their is no Menu.  I can just cycle through a half dozen different things by pressing the right button.  The left button controls the Alarm.
Here is the Serial Shutdown Tabs ans Sub Tabs.
Smart UPS C 1500
- UPS Status
- Outlet Setup
- Battery Mangement
- Diagnostics
- UPS Settings
Powerchute
- Event Configuration
- E-Mail Settings
- SNMP Settings
- Preferences
Shutdown
- Initial Setup
- Shutdown Settings
- Scheduled Shutdown
- Outlet Sequence
- Outlet Control
- Shutdown Now
Energy Management
- Energy Reporting
- Energy Savings
Logging
- Event Log
- Data Log
- Log Settings
Chuck_Finley
Chuck_Finley
Explorer
Posted: ‎2025-11-07 12:53 PM
1869
Going through the exact same thing. Not encouraging there has been no response.
Champion
Posted: ‎2025-11-10 06:28 AM
In response to Chuck_Finley
All of the relevant information and resources has been provided up above. What do you need specifically help with??
Questions Ask . . . 👍
movielover76
movielover76
Explorer
Posted: ‎2026-05-19 09:05 PM
590
Their “advice” is a load of BS. I bought my device new and it was enrolled in the online service which has now expired and they put me on the basic support plan which tells me
clearly that their is a firmware update available but it will not let me install it because I didn’t opt into extending the support plan.
if I paid $25 I would be able to update the firmware remotely from the website
all support will do if you tell them you don’t want to pay for the extended support is send you to the firmware update wizard which is clearly bad advice as it doesn’t support our model.
you really should not have to pay for firmware updates
Champion
Posted: ‎2026-05-20 12:13 AM
In response to movielover76
What isn’t supported on the SMC UPS?!? What is the UPS ID for this SKU??
movielover76
movielover76
Explorer
Posted: ‎2026-05-20 04:19 AM
566
APC 1500VA Smart UPS with SmartConnect, SMC1500-2UC Rack Mount UPS Battery Backup, Sinewave, AVR, 120V, Line Interactive Uninterruptible Power Supply
Champion
Posted: ‎2026-05-21 12:12 AM
The question was what isn’t supported and the UPS ID! Not a marketing feature listing of the system?!?! 🤦‍♂️
What is the current UPS Firmware on the system now?
