Replacement Batteries Cartridges # (number)
  • Replacement Batteries Cartridges # (number)
2151
121
Posted: ‎2021-06-29 06:49 PM . Last Modified: ‎2024-03-21 03:24 AM
1085
I can see that the same replacement battery cartridge is used for a Smart-UPS, as well as a Back-UPS, for example RBC2 which is used in the back-UPS model BK280B, and in the Smart-UPS model SU420NET.Since I just started studying about these replacement battery cartridges, do I expect to see every RBC # used for both Back-UPS and Smart-UPS models, or it just occurs for RBC2? Thanks very much,E
  • Universal Transfer Switch
Maybe this will help. Kbase answer ID #1046 goes over some batteries and the models that they use. This will hopefully will be good for you to refer to in regards to your question.
You can get to the knowledge base (kbase) at: http://www.apc.com/support/index.cfm
Although as you said, there are some UPS model # showing for RBCs, not all, this reply is very helpful. I will mark it as such!
