RS 1500 230v
  • RS 1500 230v
2151
123
Posted: ‎2021-06-29 10:49 PM . Last Modified: ‎2024-03-20 01:02 AM
1168
RS 1500 230v
I have RS 1500 model 230v, if it is on utility power its OK, i mean output voltage same as input 224v ~ 230v 50hz
but when on battery its output voltage 164v ~ 168v 60hz
please help how I manage output voltage 230v 50hz when on battery.
  • Universal Transfer Switch
Posted: ‎2021-06-29 10:49 PM . Last Modified: ‎2024-03-20 01:01 AM
how are you measuring this? with a true RMS voltmeter?
i think you are seeing this issue as explained with 120v systems here in North America except you are seeing it with 230v input.
search for FA157483 @ http://www.apc.com/site/support/index.cfm/faq/
correct, you may run into an issue with those motor type loads and this type of sinewave output. you'd need something with a pure sinewave for those motor loads.
thanks a lot
i understand many things, as this typr of UPS are only for Computer Type load, not for motor type i.e Fan etc.
