Dear Community Members,
We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience.
SE Community Team!
Quality of Charge
  • Quality of Charge
2151
Spock Teken
109
83
Posted: ‎2021-06-28 06:17 AM . Last Modified: ‎2024-03-27 12:12 AM
598
Quality of Charge
I'm putting together a protocol to assess quality of batteries charge on many of the units at my facility.  Does anyone have an idea of how to test the duration of charge remaining on a battery?  If there is equipment that gives me percentage, that is relative and possibly provides false positives for our needs.  The batteries are for BE350G units.  I must add, what is the Part Number of the stock batteries?  Part number is provided for replacement ones, but I'm just putting together testing regimen for stock ones.
Any thoughts?
Brad_C
Commander Brad_C
Commander
Most SLA batteries are rated at a C/20 rate (full discharge over 20 hours).
For capacity testing, up to a 33AH battery I use one of these : Imax B8+
To re-charge properly prior to and after a capacity test I use the Imax and then soak at float voltage with a regulated bench power supply for the best part of a day.
For example, I'm currently testing a Yuasa NP7-12. Set the Imax up for Lead Acid, Discharge current of 0.3A and 6S (12V - 6 cells in series) battery. The unit will sit there and pull 300mA from the battery until it drops below the threshold voltage (9V by default). That's a bit low, but it gives a relatively accurate measure of the batteries remaining capacity.
I recently tested a set of CSB GP1272 batteries from a SU1400RMI2U. They were 4 years old and the UPS was failing self-test. Three of the batteries measured at about 3.5Ah and one had a collapsed cell under load. So they dropped from 7.2Ah to 3.5Ah in 4 odd years.
Bear in mind a proper discharge test will take up to 20 hours, and a proper charge should probably last for 24 hours (based on a multi-stage charge and the manufacturers data sheet).
The Imax charger is not what you'd call a quality item, nor is it particularly accurate but I happened to have a couple lying around from RC hobby stuff and they turnout to be accurate *enough* to cycle test SLA batteries up to about 33Ah. I did use the B8 to test some Vision 55Ah batteries, but that took well in excess of 24 hours and the discharge rate was less than C/20 (the discharger is limited to about 20W).
The other required test is a test under heavy load. I've had batteries pass C/20 capacity tests and still collapse under heavy load. The UPS self-test is sufficient for that.
As for estimating battery capacity *without* performing a full cycle test, it's a wild guess at best. The SmartUPS series does a credible job with its battery constant calibration, but that only works with routine self tests, a decent load and lots of time.
Brad_C
Commander Brad_C
Commander
