PowerChute Serial Shutdown web interface not working
Showing results forย
Did you mean:ย
  • PowerChute Serial Shutdown web interface not working
2151
123
PowerChute Personal Edition
SCDesign
Crewman SCDesign
Crewman
Posted: โ€Ž2025-01-20 01:03 PM
1135
I'm really hoping someone here can help, I'm at my wit's end.
I have a Back-UPS Pro 1500 with battery expansion. I'm using a Windows tablet, running Windows 10, and installed PowerChute on it yesterday with the intention of using it just to monitor kWh usage of everything connected to the UPS. I don't actually need any of the shutdown features since the UPS powers a 3D printing setup.
Based on the screenshots on the website, I should be able to view kWh usage on an Energy Reporting tab. I can't find that anywhere on the localhost web interface for PCSS, and the top navigation links in the green bar don't do anything besides disappear when I tap on them.
I've tried Chrome, Edge, and Firefox, all with the same results. I've tried incognito/private mode on each. This is a squeaky-clean fresh install of Windows and each of the browsers. I've disabled ad blockers and script blockers as well.
Is there something I did wrong during setup? Here's a video of what's happening.
  • Home & Office - UPS & Software
SCDesign
Crewman SCDesign
Crewman
Posted: โ€Ž2025-01-26 03:14 PM
1
1048
I borrowed my mom's laptop and installed it on that to test whether it was the computer. Turns out what's actually going on is that the navigation drop-down menus only appear when the mouse cursor is hovered over the parent menu item. Works fine with a mouse or trackpad, less so with a touchscreen.
For anyone else scratching their head, the workaround is to simply press-and-hold on the menu item, and the drop down will appear.
Insert grumbling about accessible web design here...
Replies 5
Kirk
Posted: โ€Ž2025-01-21 12:37 PM
1111
What are the results of doing the same on the target computer that hosts the PCSS application via Chrome browser?!?
SCDesign
Crewman SCDesign
Crewman
Posted: โ€Ž2025-01-21 08:13 PM
In response to Teken
1093
As far as I know, that tablet is the target computer hosting it. It's set up with the data cable from the back of the UPS into the tablet's USB port. I don't have the UPS connected directly to the internet on its own.
Kirk
Posted: โ€Ž2025-01-22 01:04 AM
In response to SCDesign
Understood, please install the APC PCSS software on to a regular computer system (None Tablet) and report back the results.
SCDesign
Crewman SCDesign
Crewman
1
1049
Kirk
Posted: โ€Ž2025-01-27 04:24 AM
Appreciate you following up with root cause and the solution on the Windows Tablet. ๐Ÿ‘
ย
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2025 Schneider Electric
