PowerChute Serial Shutdown Service Fails to Start
Select a Country
  • PowerChute Serial Shutdown Service Fails to Start
BillP Leader
2150
150
83
Smart-UPS
BobKaiser
BobKaiser
Contributor
Posted: ‎2025-03-26 02:51 PM
2835
I installed a Quality Update for Windows 10 yesterday March 25, 2025,  2025-03 Cumulative Update Preview for Windows 10 Version 22H2 for x64-based Systems (KB5053643).  Since then, the PowerChute Serial Shutdown service will not start on  a startup / restart or when I go in as Administrator to the Services app and try to start it manually.  The service reports the error:
The Event Viewer / System log shows:
The web page for https://localhost:6547/status reports:
Unable to connect
Firefox can’t establish a connection to the server at localhost:6547.
  • The site could be temporarily unavailable or too busy. Try again in a few moments.
  • If you are unable to load any pages, check your computer’s network connection.
  • If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the web.
since the service is not running.
Do we need an update of the PowerChute Serial Shutdown software?  My current version is 1.3.0.0 11/15/2024
  • Home & Office - UPS & Software
  • Windows Service
BobKaiser
BobKaiser
Contributor
Posted: ‎2025-03-27 09:04 PM
FredKM, thank you for the advice.  I tried the repair upgrade installing the same version over the existing version.  That failed when Create Service failed to start the service.  I uninstalled PCSS, needed to do a restart.  After the restart, installed PCSS, went through initial setup.  PCSS is working now.  I am able to view the service data via the web browser at https://localhost:6547/status. Thanks again, Bob
fredkm
fredkm Troubleshooter
Troubleshooter
Posted: ‎2025-03-27 04:42 AM
Note that KB5053643 is an optional update. I tried to replicate your issue by installing this update, but for me the PowerChute Serial Shutdown 1.3 service starts normally after installing the update and restarting the OS.
You could try to uninstall and re-install PowerChute Serial Shutdown and see if that resolves the issue. Or maybe first try a repair upgrade installation (install the same version again which will preserve your existing configuration).
If that doesn't help, then see if uninstalling KB5053643 fixes the issue.
BobKaiser
BobKaiser
Contributor
