Bypass out of Tolerance-Silcon40kva
Select a Country
  • Bypass out of Tolerance-Silcon40kva
BillP Leader
2150
147
83
Posted: ‎2021-06-29 02:32 AM . Last Modified: ‎2024-03-22 02:28 AM
6488
What causes this alarm for Silcon 40kva? "Bypass out of Tolerance".
Is this a normal condition for UPS? Any corrective actions for this?
Thanks in advance?
upsguy_apc
upsguy_apc
Contributor
6485
As the post below says bypass out of tolerance means that they utility input to the UPS is outside of the tolerance envelope for either voltage, frequency or both. When this happens the silcon cannot switch to bypass in the event of a UPS component failure. Also at this point the UPS may begin drawing current from the batteries to continue powering your load.
If the UPS is dual sourced check to make sure the bypass input breaker is closed.
Replies 4
upsguy_apc
upsguy_apc
Contributor
6486
Posted: ‎2021-06-29 02:33 AM . Last Modified: ‎2024-03-22 02:28 AM
Thanks in advance?
Nzox
Nzox
Explorer
Posted: ‎2025-03-25 12:53 AM
In response to upsguy_apc
1865
What if the bypass source is similar to UPS input (there are jumpers from UIB to SSIB terminals) and it keeps alarming bypass out of tolerance without input out of tolerance alarm?
Safiul
Safiul
Explorer
Posted: ‎2025-12-25 06:50 AM
In response to Nzox
You can customize the acceptable tolerance voltage/frequency value from the service menu.
