Posted: 2024-10-25 09:50 AM
Good day, I need to get the true output of a SMART-1000 with NMC 2.
For hours I tried all OIDs I had available, but none delivers the output by Watt.
I can get output load, but that gives VA% - useless in my case.
Output current doesn't help either as it remains "0" as long as power is below 1 amp.
The Web gui at least shows "Output Watts %", which would be OK to calculate load then, but I can't get this value by SNMP.
Last resort I thought about parsing the gui page, but this requires username/password, so no success either.
any help appreciated
Posted: 2024-10-28 06:39 AM
You may give this a try and report success / failure. 👍
The OID is 1.3.6.1.4.1.318.1.1.1.4.2.8.0
Posted: 2024-10-30 05:22 AM
@Teken Thanks for the hint.
Unfortunately the value reportedby the UPS is "0"
Posted: 2024-11-04 05:28 AM
Would you kindly submit a service request with APC Technical Support. To obtain the correct information and once received please share the same here for the benefit of others. 👍
Apologies that OID string didn’t work. ☹️
Posted: 2024-11-30 09:08 AM
I did open a ticket, but did not get any answer unfortunately.
As I cannot wait any longer, I solved my issue by buing a Shelly PlugS, five minutes efforts and it delivers what I need (and more).
Posted: 2024-12-02 04:56 AM
They didn’t reply or wasn’t able to provide an answer?!?
Posted: 2024-12-02 11:00 PM
They didn't answer at all
