I have a SMART-UPS RT 3000 and it happened a error and some transistors are
  • I have a SMART-UPS RT 3000 and it happened a error and some transistors are
2151
121
Posted: ‎2021-06-29 07:39 PM . Last Modified: ‎2024-03-21 02:39 AM
1198
I have a SMART-UPS RT 3000 and it happened a error and some transistors are burned and i can not see the numbers that are named the transistors.how can you help me
Message was edited by: ektor
Posted: ‎2021-06-29 07:39 PM . Last Modified: ‎2024-03-21 02:38 AM
APC doesn't provide technical details to end users like us. If it is under warranty, I'd suggest setting up a return for repair. If it isn't under warranty, you'd need to consider the trade-off of a repair vs. a replacement unit. The official non-warranty repair facility is [Coastal Business Machines|http://coasttec.com/].
Some end users here have performed component-level repair. The only thing I'd caution is that when some parts fail, they often take other parts with them and it may not be obvious which was cause, which was effect, and all of the parts that need to be replaced. You can replace the obvious parts, plug it back in, and have the same problem happen again right away.
