Send InviteCancel
Posted: 2025-09-2904:22 PM
Forced Power-Cycle with Back-UPS BX500MI
let me 1st leave a few words on myself. I'm retired, was working in networking-business for some 30 years and have some experience in IT/OSs/programming from that.
I recently bought 2 new APC-devices, one listed in subject to replace an existing without any steering-capabilities.
Target is to protect 2 Proxmox PVEs I'm using NUT-server and client for that via the USB-port to the UPS.
Generally the shutdown works well and likely (tests are time-consuming) also the recovery once the UPS shuts down the outputs and power gets back.
The other options have no action besides logging and I removed the lines for logger.
If battery.charge gets below battery.charge.low, the NUT-server starts forcing the clients to shut the Proxmox-guest-SW and the PVEs shut down well - all as expected.
If now the power comes back (perhaps before above 180s passed), the UPS keeps the output power untouched and due to that these servers stay down. I hoped that "load.off.delay 180" is sth the UPS remembers regardless of input, but if the NUT-server is responsible for that - that's already down then.
Am I missing sth? Should this be doable at all? What else would be needed to achieve a power-cycle, once the shutdown was triggered on clients.
