Posted: β2021-06-29 06:09 AM . Last Modified: β2024-03-21 05:45 AM
Hi all,
I have a Back-UPS ES 750 on a workstation that draws 250 watts at startup. Steady state, no CPU load is around 115 watts (as measured by a Kill A Watt. The unit is only about 2 years and passes self test just fine. I pull the plug to test it and it's as if there's no UPS there at all.
Ideas?
thanks,
-greg
Posted: β2021-06-29 06:09 AM . Last Modified: β2024-03-21 05:44 AM
Greg,
Have you tried using a much more smaller load like a 60W light bulb? Is this the first time that this had happened?
That's nice to hear that you got it all working now. Feel free to reach us again should you have any comments, questions, suggestions or issues.
I hooked up the ES 750 to a wimpier desktop (only 2 hard drives and an Athlon CPU. Startup is about 100 watts and steady state (no load) is about 60+ watts. Still same result - pull the plug and boom. Powerchute (personal) doesn't even register an event.
Actually I just connected a scanner which drew 20W and it died immediately when I unplugged UPS from the wall.
I also just pulled up the scanned QA test dated 7/17/09, so I guess I need to check warranty period now. My guess is 1 year.
Message was edited by: mcunix
I am an idiot. I've been in IT for 30 years, but wasn't using the correct plug. It's dark under my desk π
Works fine with the correct outlet used.....
Greg,
