Cryptic Smart UPS C1500 Configuration. What do these codes mean?
Showing results forย
Did you mean:ย
  • Cryptic Smart UPS C1500 Configuration. What do these codes mean?
2151
119
83
Smart-UPS
vinnysaj
vinnysaj
Cadet
Posted: โ€Ž2024-11-22 04:32 PM
2
2668
The Smart UPS C1500 has a very limited screen, so the cryptic configuration names are expected, but I cannot find any information in the manual about some of the configurations. Specifically, I want to calibrate my battery and enable smart connect control.
SE.0 -> Performs a self test when set to SE.1, I am pretty sure
P9.3 -> Sensitivity setting
dP.1 -> Unknown
cP.0 -> Unknown
Gn.0 -> Green mode (0 off, 1 on)
rc.0 -> Unknown
rb.0 -> Unknown (Has a battery with X symbol. Unknown what this is)
cod -> This switches between multiple codes, but I left it as this because I have no idea what any of the other codes mean
FU.1 -> Unknown
This UPS also only has 3 buttons, power, mute, and display. To enter this config menu you have to hold both the display and mute buttons. Mute changes the setting on-screen, and display increments through the menu.
I've searched between multiple editions of the manual for this unit and have not found full information as to what all of these codes mean. Wondering if anyone else here has any idea?
Additionally I am seeing a L.02 code which means battery must be replaced. Just replaced the battery, so assuming that I need to now run a calibration or something to get this code to go away. Knowing the configuration will let me do this.
  • Home & Office - UPS & Software
Kirk
Posted: โ€Ž2024-11-23 02:18 PM
1
2570
I have appended the user manual I believe you are asking about for this APC UPS. On page 11 calls out how to enter the configuration mode. On page 13 calls out how to enable the Smart Connect remote commands and also reset the battery replacement flag.
You should be able to enter the battery installation date via APC Power Chute software too.
To properly inform the system a battery has been inserted follow these steps:
- Update the battery installation date if available in PCBE / PCSS / LCD. Doing so resets the counters and charging tables if applicable.
- Self Test: Manually initiate this via LCD / PCBE / PCSS and let battery come back to 100% and online state.
- Battery Calibration: Initiate the battery calibration via the PCBE / PCSS software if available with at least 30% attached load on the outputs of the UPS. Let this process complete and battery to fully charge and show on-line.
Doing so will ensure the LCD / Power Chute software will reflect the operational runtime when on battery only mode. Keep in mind the value displayed is an estimate and does (NOT) reflect all possible environmental conditions such as load, battery health, SOC, etc.
Questions  Ask - If not please consider marking this reply as a solution. So it may help the next person asking the same. ๐Ÿ‘
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://download.schneider-electric.com/files?p_enDocType=User+guide&p_File_Name=SU_UM_990-5444E_MN0...
Kirk
1
2571
vinnysaj
vinnysaj
Cadet
Posted: โ€Ž2024-11-24 11:09 AM
In response to Teken
Awesome. Out of the 4 manuals I found online, none were as descriptive as this one. Thanks!
ย
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2025 Schneider Electric
