Correct Power Chute USB Cable?
Select a Country
  • Correct Power Chute USB Cable?
BillP Leader
2150
147
83
Posted: ‎2021-06-29 03:47 AM . Last Modified: ‎2024-03-22 01:12 AM
3401
I need to know what Power Chute USB Cable number for the DLA3000RMT2U UPS. I have cables marked 940-0127B which has a RJ50 connector on one end. The UPS has a regular USB connection and a serial connection. Thank you for your help
Replies 5
I did get a flashlight and looked closer at the connector and it is a RJ50 10 pin phone like connector not a USB connector, It was misleading to me as it is labled USB and that is the kind of connector I was looking for. So the unit does come with the correct connecting cable. It would have a more clear meaning if it was labeled TO USB.
What will the Power Chute software allow me to do? Can I change the input and output voltages and the battery power voltage? In other words as just a home computer owner, would it be a useful tool as the unit seems to work fine.
What will the Power Chute software allow me to do? I would like to adjust input voltage, output voltage, and the battery power voltage.
BillP Leader
Leader
3397
I apologize for the inconvenience this has caused you. With regards to your question about PCBE (PowerChute Business Edition) here is a link on the product information page --> http://www.apc.com/products/family/index.cfm?id=125. PCBE provides UPS management and monitoring, event and data logging, UPS sensitivity adjustments and the high and low input voltage adjustments to name a few. Input and output voltages can be adjusted if your UPS supports it. For software compatibility please feel free to view the Operating System Compatibility Sheet here --> http://www.apcmedia.com/salestools/ASTE-6Z5QEV_R21_EN.pdf
JonPro
OborKnez
OborKnez
Explorer
Posted: ‎2025-05-30 12:19 PM
In response to BillP
Ok still doesn't understand the problem and solution. I wont to connect SMT1500IC with powerchute businesses edition 9.5 plus i think. I have Rj50 and usb A cabel. But powerchute doesn't seems to find the UPS on any port listed and in device manager there is no other port than com 3 and com 4 which is virtual an resrved i think for some blueberry service...... Help?
