Back-UPS RS 900G: PC Won't Start
Showing results forย
Did you mean:ย
  • Back-UPS RS 900G: PC Won't Start
2151
119
83
lmstearn_apc
Ensign lmstearn_apc
Ensign
Posted: โ€Ž2023-04-12 09:59 PM . Last Modified: โ€Ž2023-04-12 10:08 PM
1135
Connect this PC directly to the mains, it starts up from hibernation, connected to the UPS, no sign of life. Older rigs start when connected to the UPS. Fixable by tweaking the UPS or UEFI?
Thanks.
lmstearn_apc
Ensign lmstearn_apc
Ensign
Posted: โ€Ž2023-10-16 03:26 AM . Last Modified: โ€Ž2023-10-17 10:42 PM
992
Still an issue with hibernation, along with this one, thought there was a workaround, might have slipped user memory. Did forget to mention the Cooler Master MWE Gold Fully Modular 650W Power Supply, and the UPS batteries probably just past the three year mark.
Tried plugging the PC into different sockets on the UPS, no change.
Interesting thing is that after powering off and on the UPS, the PC boots up when the power on button is activated! An easy solution, but for the hurt to the Synology NAS also connected to the UPS. ๐Ÿ˜ฐ
Edit: Issue isn't just with hibernation either, shutting down Windows and switching off the PC box will not make the PC power on button work next time either. Could it indeed be a faulty lead or something else causing residual power leak?
Tried the suggestions in the ASUS Unable to Wake up, and Three Ways to Turn Off, no dice.
The BIOS has these options:
Spoiler
CPU Power Management Control
 This item allows you to manage and configure the CPUโ€™s power.
Intel(R) SpeedStep(tm) [Auto]
 This item allows your system to support more than two frequency ranges. . Configuration options: [Auto] [Disabled] [Enabled] ]
CPU C-States [Auto]
 This item allows you to set the power saving of the CPU states. .Configuration options: [Auto] [Disabled] [Enabled] ]
Remarks
The following items appear only when you set the CPU C-States to [Enabled].
Enhanced C-States [Enabled]
 This item allows your CPU to reduce power consumption when the system is in idle mode. Configuration options: [Enabled] [Disabled]
CPU C3 Report [Enabled]
 This item allows you to disable or enable the CPU C3 report to the operating system. Configuration options: [Enabled] [Disabled]
CPU C6 Report [Enabled]
 This item allows you to disable or enable the CPU C6 report to the operating system. Configuration options: [Enabled] [Disabled]
CPU C7 Report [Enabled]
 This item allows you to disable or enable the CPU C7 report to the operating system. Configuration options: [Disabled] [CPU C7] [CPU C7s]
CPU C8 Report [Enabled]
 This item allows you to disable or enable the CPU C8 report to the operating system. Configuration options: [Enabled] [Disabled]
Package C State limit [Auto]
 This item allows you to set the a C-state support for the CPU package. Configuration options: [C0/C1] [C2] [C3] [C6] [C7] [C7s] [C8] [Auto] [Enabled]
CFG lock [Disabled]
 This item allows you to enable or disable the CFG lock. Configuration options: [Disabled] [Enabled]
The keyboard and mouse are configured to wake the rig, for some reason they won't, Not sure either if modifying any ASUS Overvoltage Protection, CPU C-States, PCH or DMI would help. Changing ASPM perhaps?
Right now, Using a custom power plan on the rig, could the Ryzen balanced power plan make all these woes disappear?
Salvatore had a similar issue, is hibernation a lost cause, or is there any HW that can deal with it?
Thanks again. ๐Ÿ™‚
Edit 2: Resolved, installed PCE and "Set Power Consumption Threshold" to 60. Totally missed that! ๐Ÿ˜‚
lmstearn_apc
Ensign lmstearn_apc
Ensign
993
Spoiler
CPU C-States [Auto]
Remarks
CFG lock [Disabled]
Thanks again. ๐Ÿ™‚
lmstearn_apc
Ensign lmstearn_apc
Ensign
Posted: โ€Ž2024-10-18 03:34 AM . Last Modified: โ€Ž2024-10-18 07:26 AM
In response to lmstearn_apc
Ugh, all of this did escape the memory before connecting the little HP SFF.
Did replace the batteries to the unit as it was purchased mid-2018(?), same issue so the threshold settings look like they set on the PC rather than the UPS?
Google was given a test drive on it - do the settings reset to default after power off/battery ?replacement?
Also as this is a discontinued item, the Powerchute Personal software support is pulled in December, will the replacement driver still work with the unit?
Are there alternative similar APC products using this battery type that can be recommended for future consideration?
Thanks again. ๐Ÿ˜€
ย
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2025 Schneider Electric
