Back-UPS ES 350 battery query
  • Back-UPS ES 350 battery query
2151
Spock Teken
107
83
Posted: ‎2021-06-28 06:01 AM . Last Modified: ‎2024-03-27 12:29 AM
1195
Hi there
My Back-UPS ES 300 is reporting 0% battery charge, despite being on mains power.  The status is showing as 'ONLINE LOWBATT' but there is no alarm sounding, nor is the 'Replace Battery' light on.
Sounds like I should replace the battery but I wonder if there is a problem with the UPS itself (and therefore I'd be better buying a new unit).  Any thoughts?
Here is the full output from apcaccess:
APC : 001,045,1061
DATE : 2017-05-26 15:41:20 +0100
HOSTNAME : pelham
VERSION : 3.14.14 (31 May 2016) debian
UPSNAME : miniups
CABLE : USB Cable
DRIVER : USB UPS Driver
UPSMODE : Stand Alone
STARTTIME: 2017-05-26 15:41:18 +0100
MODEL : Back-UPS CS 350
STATUS : ONLINE LOWBATT
LINEV : 224.0 Volts
LOADPCT : 1.0 Percent
BCHARGE : 0.0 Percent
TIMELEFT : 0.0 Minutes
MBATTCHG : -1 Percent
MINTIMEL : 3 Minutes
MAXTIME : 0 Seconds
OUTPUTV : 230.0 Volts
SENSE : Medium
DWAKE : 0 Seconds
DSHUTD : 180 Seconds
LOTRANS : 180.0 Volts
HITRANS : 266.0 Volts
RETPCT : 0.0 Percent
ITEMP : 29.2 C
ALARMDEL : 30 Seconds
BATTV : 12.1 Volts
LINEFREQ : 50.0 Hz
LASTXFER : Automatic or explicit self test
NUMXFERS : 0
TONBATT : 0 Seconds
CUMONBATT: 0 Seconds
XOFFBATT : N/A
SELFTEST : NO
STESTI : None
STATFLAG : 0x05000048
MANDATE : 2010-12-20
SERIALNO : 4B1052P01898
BATTDATE : 2010-12-20
NOMOUTV : 230 Volts
NOMINV : 230 Volts
NOMBATTV : 12.0 Volts
NOMPOWER : 210 Watts
FIRMWARE : 807.q10 .I USB FW:q
END APC : 2017-05-26 15:41:21 +0100
Thanks in advance.
Chris
Brad_C
Commander Brad_C
Commander
On 27/5/2017 12:43 AM, Bill said:
If the battery is reading less than 12.5 it is bad which seems to be the case based on the information APCUPSD is showing NOMBATTV : 12.0 Volts.
Actually, NOMBATTV is Nominal Battery voltage. That is however many cells in the ups x 2.0v and is calculated rather than measured. So my SUA3000 shows a NOMBATTV of 48V with a measured BATTV of 55.4V. His showed a NOMBATTV of 12.0V and a BATTV of 12.1V. Either way, 12.1 is way too low.
That unit is 5 years old so it is time for a replacement battery. If you look at the bottom of the unit the bar code sticker should show the actual model to be BK350i. The replacement battery is part number RBC2. You can find the battery at http://www.apc.com/us/en/tools/upgrade_selector/index.cfm or from a local partner.
If you pull the battery and check it with a DC volt meter a good battery would read around 13 volt. If the battery is reading less than 12.5 it is bad which seems to be the case based on the information APCUPSD is showing NOMBATTV : 12.0 Volts.
That's very helpful, thanks.
Brad_C
Commander Brad_C
Commander
