BX900R Red "Replace Battery" flashes - "Battery disconnected" status
  • BX900R Red "Replace Battery" flashes - "Battery disconnected" status
2151
120
Posted: ‎2021-06-29 03:48 AM . Last Modified: ‎2024-03-22 01:11 AM
936
Hi
BackUPS XS Series BX900R
Serial number: JB0748013060
When I got home yesterday my PC was shut down and the red "replace battery" indicator was flashing. I have tried other cells in the unit and the situation persists.
In powerchute, I see status "Battery Disconnected".
Anything that you can help me with?
Thanks in advance
Posted: ‎2021-06-29 03:49 AM . Last Modified: ‎2024-03-22 01:11 AM
Hi
Thanks in advance
Replies 8
The batteries seem to be fine. They were all connected (has been working for at least 12 months), not swollen or cracked or unusually hot or anything. I measured the voltage at 13.1 volts on both of them.
At first, I turned on the PC and it would work fine but after 15 minutes, the PC shut down. Then it would not start for more than a couple of minutes before sutting down again. That's when I disconnected the PC from the UPS and plugged it back to the utility.
Then I used 2 other batteries from other appliances and tested it, same result (Red flashing light). Both batteries had good voltage. (fully charged).
Message was edited by: mamethot
If you have tried different batteries already and it does the same thing, flashing replace battery and failure to support he load when you do a pull-plug test then the unit had encountered a fault.
All rightm then I need to go through a warranty claim...thanks.
Can you send me a PM with your contact details on it? Like the business name and address if this UPS is being used for business. Then your personal details i.e. complete name, address, position, phone and mobile number. I'll check if this unit is within the factory warranty period.
I already received your PM and have responded back using the e-mail that is posted on your forum profile.
Great service, thank you!
You are welcome. Details has been e-mailed already.
Hi
Thanks in advance
