BX1500G Behavior erratic
  • BX1500G Behavior erratic
2151
120
Posted: ‎2021-06-28 05:32 AM . Last Modified: ‎2024-03-27 12:54 AM
746
Purchased 20 Feb 2011: Original Batteries.
Before I purchase batteries I want to see if I should. There are some odd symptoms:
  • When the power is turned on, the UPS LED shows a power input of 262, 40, 50, ... before settling to about 120V. No load applied.
  • When no load is applied, the UPS operates normally.
  • When a 115W load is applied and the UPS has input power, the UPS intermittently
    • Shows input voltage cycling (see above)
    • Alternatively shuts down and restarts.
    • There is a ;clicking' noise (no beeping).
    • The battery LED  shows full.
It is (quite) possible that a new battery is needed, but the voltage cycling on/off state cycling and being unable to carry a load is baffling. The bottom line, do I need a new battery?
  • battery
  • beeping
  • load
  • power
  • ups
Hi Arthur,
With the symptoms you are describing, it sounds like there is an internal issue with the unit itself, not the battery. A bad battery would not affect the AC voltage readings or frequent clicking like that. With the unit being at least 6 years old, it is near end of life anyway (expected life is 7-10 years), I would recommend unit replacement.
Hi Arthur,
