Posted: 2024-09-23 02:19 AM
I've bought a BR1600SI to protect my home lab
Is attached to pfsense machine using a nut server that coordinate shutdown of all the component of the lab.
The total power usage of the lab is less than 300w when active and less than 90 on idle.
The problem is that the device detach power during self test.
How is that?
No error is reported by the device
Thank You
F
Posted: 2024-09-23 05:47 AM
There’s an obvious conflict / configuration and setup problem in your deployment.
You can at least validate if the system operates as expected by connecting the UPS to a computer running APC PCPE / PCSS software.
Manually initiate a Self Test via APC PCPE / PCSS what are the results?!?
Posted: 2024-09-23 01:09 PM
I'll try tomorrow a post the results
Posted: 2024-09-26 12:24 PM
The selftest completed without as passed and without disconnecting the power.
What do you suggest to do?
Posted: 2024-09-27 03:33 AM
It’s not clear to me what you stated up above?!? The Self Test completed successfully using the APC Power Chute Software - YES?!?
