BE700G-UK Serial number 5B1505T04154
  • BE700G-UK Serial number 5B1505T04154
2151
120
Posted: ‎2021-06-28 06:50 AM . Last Modified: ‎2024-03-26 11:06 PM
454
Been given this for my daughters Imac so she can use it at university when doing her course work
i have plugged it in and all i get is a constant high pitched tone and a red flashing light
any advice will be appreciated
That indicates the UPS is overloaded. If there is no load then you should reset the unit.
1: Disconnect any attached load.
2: Unplug the UPS from the wall socket.
3: Disconnect the UPS' internal battery.
4: Push and hold the "On" button on the UPS for 5 seconds
5: Reconnect internal battery.
6: Plug UPS in to known good power source.
7: Turn UPS on.
If after the reset the unit still alarms it will need to be replaced.
7: Turn UPS on.
