BE500-PH reset PC
  • BE500-PH reset PC
2151
120
Posted: ‎2021-06-28 08:19 PM . Last Modified: ‎2024-03-26 01:26 AM
1657
BE500-PH reset PC
BE500-PH reset my PC during a power outage (less than a second), the speakers make a short noise, the light bulb of the room blink and the UPS makes a sound like hit metal (about 2 times)
The UPS were fully charged (12h)
I unplug the UPS to check if the UPS works, and works fine
The UPS have 3 battery powered outlet
- midtower duron 1.2Ghz
- monitor 14" crt
- router xavi
1 surge protected outlet
- switch encore 8 port
Message was edited by: carlosso
- monitor 14" crt
- router xavi
I bought UPS a week ago.
In Peru the voltage is: 220 VAC and 60 cycles.
BE500-PH:
input:
- Voltage/frequency: 220 VAC/57-63Hz
- Low voltage transfer: 180 VAC
- High voltage transfer: 260 VAC
output:
- UPS capacity (3 battery powered outlets): 500VA/300Watts
- Surge capacity (all 4 outlets): 5 Amps
- Voltage (on battery): 220 Vrms +8/-8%
- Frequency (on battery):60 Hz +/- 1Hz
- Transfer time (ms): 8ms typical, 10 ms max
Surge Protection:
- AC Surge Protection: 450 Joules
- Telefhone surge protection: nome
- AC input protection: circuit breaker switch
Battery:
- Battery type: sealed lead acid
- Recharge time:10-12 hours
- Average life span: 2-4 years
The page of APC Peru (http://www.apc.com/?isoCountryCode=pe) has an address, but no email, i will try to contact
TheNotoriousKMP_apc
Sisko TheNotoriousKMP_apc
Sisko
Just to provide some assistance I found this:
080051849 / +5511 4689-8600 techsupportlatinamerica@apcc.com
- monitor 14" crt
- router xavi
