BACK UPS ES 700 controlled outlets stopped powering off
Select a Country
  • BACK UPS ES 700 controlled outlets stopped powering off
BillP Leader
2150
150
83
Darcey
Darcey
Contributor
Posted: ‎2022-05-02 05:32 AM . Last Modified: ‎2022-05-02 05:39 AM
2605
I have always used this UPS with the controlled outlet feature enabled and it has worked without issue for several years.
Recently, power to the controlled outlets is no longer truned off when the computer (on master outlet) is shut down or put to sleep.
What I have tried:
1. recallibrate the threshold with PC powered up, disconnected, powered off, and in suspend.
2. 'reset' the UPS by disconnecting mains, removing battery, leaving it for a while, then powering up on battery only. Then connecting mains.
Also, since this issue started a couple of days ago, I have noticed the PC has powered up in the middle of the night (from a power off state NOT sleep). With this particular PC, this can happen if you disconnect & reconnect mains with or without UPS). This suggests (to me) that the UPS may have momentarily cut power to the master outlet.
The current battery (9Ah) is about 6 months old.
What might cause the controlled outlets to stop powering down and what might I try to fix it?
Also, if it is a fault I cannot fix, what is the recommended replacement? It seems current APC BACK UPS line up do not offer the controlled outlet feature.
Many thanks.
Replies 6
JonPro
JonPro Troubleshooter
Troubleshooter
Posted: ‎2022-08-26 03:04 AM
2401
hi @Darcey
Thank you for reaching out to the SE Community, my name is Jon and I will assist you with this query.
Apologies for the late revert on this post, based on your description one possible cause is the failure with the sensor/switching mechanism of the master outlets.
Will you be able to share the model and/or the country where you're from?
Darcey
Darcey
Contributor
Posted: ‎2022-08-26 08:25 AM . Last Modified: ‎2022-08-26 08:26 AM
In response to JonPro
2394
@JonPro  Thank you for responding to my post.
The unit is a BE700G-UK and I am in England.
The UPS was purchased 2010! It has performed flawlessly other than the controlled outlets stopped turning off with the master. So no complaints! However I really like that feature and it seems it's no longer present on any APC UPS these days.
If I can, I'd like to try and repair it. It will help me save electricity and that will be very welcome given the UK's extortionate energy prices!
Many thanks.
Darcey
Darcey
Contributor
Posted: ‎2022-09-27 01:43 AM
In response to Darcey
2338
@JonPro
I know this is an old unit but I'd be very grateful for any pointers.
BTW if Schneider/APC offered a similar unit nowadays, I would buy it without hesitation. Considering the current energy crisis and  prevailing climate debate, the current UPS offerings seem to have missed a trick by dropping the controlled outlet feature.
JonPro
Troubleshooter
Posted: ‎2022-09-27 05:58 PM
2328
Hi @Darcey
I have tried checking our BackUPS product line for the UK and it does appear that the models that have this master control feature are no longer available.
SmartUPS SMX and SRT models would have controllable outlets.
Darcey
Darcey
Contributor
Posted: ‎2022-10-08 08:11 AM
1
2301
@JonPro Thank you for the suggestions. They seem very capable units but over my budget. The unit functions correctly other than the controlled outlets. I will continue using it and investigate repair options.
JonPro
Troubleshooter
Posted: ‎2022-10-10 03:23 PM
You are welcome @Darcey
