BACK-UPS CS 650
  • BACK-UPS CS 650
2150
127
Posted: ‎2021-06-28 08:12 AM . Last Modified: ‎2024-03-26 03:35 AM
2370
BACK-UPS CS 650
Hello, sorry for my English, I hope who read could understand it.
We have an old BACK-UPS CS 650 into the office, of which I didn't have the chance to recover the PC connection cable, so I wanted to know if it was possible to monitor it using a LAN cable in the Data port of the UPS and a LAN-USB adapter for the USB input in the laptop I would use to monitor the battery.
I tried to install the PowerChute software on the laptop but the installation always tells me that it doesn't signal the battery so it doesn't work (Attached I put the message that comes out during the installation; it is in Italian, I hope you can understand what it is all about). Do I have to do something else before, or some operations to do? Or  does the mistake message depend from the use of the LAN-USB adapter? What I have to do to check the battery?
Thank you so much in advance.
2370
Hi Stefania,
It is not possible to monitor the UPS by using a LAN cable in the Data port of the UPS and a LAN-USB adapter for the USB input in the laptop.
The PowerChute software will install when the laptop detects that it is connected to a UPS. Once you have the correct cable, the installation will work.
I will send you a message with details on how to get the correct cable.
Tom
2371
Hi Stefania,
Tom
mrtsb
mrtsb
Cadet
Posted: ‎2023-12-28 03:16 AM
In response to BillP
Hi, This is Mike, I also need the same cable, perhaps I could how do I get one?
Thanks in advance
Mike
mrtsb
mrtsb
Cadet
Posted: ‎2023-12-28 03:23 AM
Hi, I have the same issue, I am using a CS650 and now want to connect my QNAP Nas using the
USB Data cable but unfortunately have lost it.
Perhaps you could share the info of where I could obtain one from.
Thanks in advance
Mike
mrtsb3061@gmail.com
