Apc smart ups c1000 no communication via LAN and USB
  • Apc smart ups c1000 no communication via LAN and USB
2151
120
jns
Crewman jns
Crewman
Posted: ‎2024-12-23 01:58 AM
810
Apc smart ups c1000 brak komunikacji przez LAN i USB. komunikat o błędzie wskazujący, że instalator PowerChute Personal Edition 3.1.0 nie może znaleźć podłączonego UPS APC (zasilacza awaryjnego). Jakiego programu powinienem użyć do komunikacji z UPS przez USB lub LAN?
SMC1000IC : APC Smart UPS SMC Line Interactive, 1000VA/600W, wolnostojący, 230V, 8x gniazdo IEC C13, port SmartConnect, AVR
SMC1000IC
AS1939161977
  • Home & Office - UPS & Software
Kirk
Posted: ‎2024-12-23 02:35 AM
798
Your specific model can use the APC Smart Connect over the WAN. You need only follow the instructions to register and enroll your system for the six month free trial.
Afterwards you’ll need to purchase a ongoing subscription for the level of service you want.
You may try the APC Power Chute PCSS vs PCPE software instead to see if it connects over USB using the supplied data cable.
Questions Ask . . . 👍
Replies 5
Kirk
799
jns
Crewman jns
Crewman
Posted: ‎2025-01-01 11:39 PM
In response to Teken
The error message indicates that PowerChute cannot connect to the Network Management Card (NMC) at 10.0.0.242 via HTTPS on port 443. error ups.JPG
jns
Crewman jns
Crewman
Posted: ‎2025-01-01 11:43 PM
719
Date Time Event
Date
Time
Event
2025-01-02 08:40:11 Cannot connect to https://10.0.0.242:443
2025-01-02 08:40:09 PowerChute cannot communicate with the Network Management Card.
2025-01-02 08:24:17 PowerChute successfully accessed TCP port 6547.
2025-01-02 08:24:17 PowerChute is attempting to access TCP port 6547.
2025-01-02 08:24:15 PowerChute Network Shutdown version 5.1.0 monitoring started.
2025-01-02 08:24:13 PowerChute successfully accessed UDP port 3052.
2025-01-02 08:24:13 PowerChute is attempting to access UDP port 3052.
2025-01-02 08:24:13 ERROR: The ini contains an invalid value for localHostAddress in section Networking.
Kirk
Posted: ‎2025-01-02 03:59 AM
In response to jns
699
What version of APC Power Chute Software are you using?!? You can only use PCBE / PCSS software which needs to be connected via USB cable.
jns
Crewman jns
Crewman
Posted: ‎2025-01-03 06:19 AM
I use PowerChute Network Shutdown
version 5.1.0
