Analyzing Power Consumption
  • Analyzing Power Consumption
2150
127
Posted: ‎2021-06-29 07:51 PM . Last Modified: ‎2024-03-21 01:32 AM
2506
I have 4 APC 6000RT's in various offices. Is there a way to extrapolate a good baseline on power consumption from the data presented on the Status page? Management wants to know what the load is in Watts/VA and the system reports the Load Power in %Watts and %VA - not sure what this means.
Any clarification?
Thanks in advance.
  • Universal Transfer Switch
i am not sure what you are doing exactly haha..
here is what i did if you just want to find out how much load the UPS is drawing in watts or VA:
VA: 3.68A * 208v = 766.44VA (12% of 6000VA = ~720VA so this is pretty close)
Watts: 14% * 4200 watts = 588 watts
also, input power factor is .95 and output power factor is .7
well, the SURT6000XLT maxes out at 4200 Watts / 6000 VA. if you have the percentages of what is in the status page/data log on the network management card, you can figure out what load is being drawn. dont forget to factor in whether you are using 208v or 240v when calculating volt amps.
hope this helps or let me know if i can provide any more information.
That does because I think I've been taking the long way around with calculating this.
This is currently what is being reported from one of them:
Power
Input Voltage: 204.4 VAC
Bypass Input Voltage:
Output Voltage: 209.4 VAC
Current:
Input Frequency: 60.01 Hz
Load
Load Power: 14.0 %Watts
Apparent Load Power: 12.0 %VA
Load Current: 3.68 Amps
Battery
Capacity: 100.0 %
Battery Voltage: 218.1 VDC
External Batteries: 2
My calculations:
Load power on output of UPS = 6.08A * 207.0 Vac = 1259 VA
UPS output power capability = 4200 W
The present load at (1259 VA / 4200 W ) *100% = 30% capacity of the UPS (quite low, so probably the effic is at ~ 70%, estimate )
Assuming UPS efficiency (Output PWR / Input PWR) = 70%
Load power from the wall (input of UPS) = 1259 VA / 0.7 = 1799 VA
Load current from the wall (input of UPS) = 1799 VA / 216V ac = 8.3A ac
Thoughts?
Edit: My calculations don't match what's being reported above. But the gist should be the same.
Message was edited by: mechanyx
