Continue
  • My Subscriptions
  • Events
APc Smart-UPs 1000 Problem
  • APc Smart-UPs 1000 Problem
BillP Leader
2151
154
Techie_apc
Techie_apc
83
Posted: ‎2021-06-28 09:33 PM . Last Modified: ‎2024-03-26 12:23 AM
2070
Now The Battery is daed and i looked and nothing is burnt broken or fried or smells fried but when i plug it is nothing happend when i press the power button no lights or anything so i took the battery from my BEST small backup...the battery works but the BESt system might be messed i dont know ok so i hookup the battery from the BEST system (it was charged) to the Smart-UPS 1000 and then Pressed the power button and i herd a beep and all the light turned on and fadded as the small battery died but why dosent the land power work...
Can i wire the plugs from Utility Power to the battery connectors or will it fry it? If i can that would make it work... i dont know what is wrong i tryes turning the Sensitivity In both ways alot and pressing power and nothing BUT when the small BESt system battery is plugged in and it is off then i connect Utility Power and i hear another beep...and i connected the ternamals from the BEST system board to the Smart-UPS 1000 Battery Ternamals and i hit power and i herd BEEP,Lights Brighter then fade,BEEP,Click,Click...Click..Click then when i disconnect i hear Beep but the beeps fade so i really need help it does have batterys (dead) but with Utility Power and the BEST Battery Nothing still turns on just BEEP
Utility Power Dosent Work But Battery Power Does...Can Anyone Help?
Posted: ‎2021-06-28 09:33 PM . Last Modified: ‎2024-03-26 12:22 AM
DO NOT connect utility power to the battery terminals. If your UPS is still usable, this will be a sure fire way to destroy it beyond economical repair. You need around 24v DC at battery terminals before the unit will ok power on. So, without knowing the voltage of your Best UPS battery pack, there's no way to tell where the problem is.
With your level of skills, I do not recommend messing with it. At best, you'll destroy the UPS. At worst, you'd be in the ER or explaining to the insurance company why your house caught on fire.
TheNotoriousKMP_apc
TheNotoriousKMP_apc
Contributor
Based on what you're describing, it seems you may have a 3rd Generation Smart-UPS. I'm guessing the part number may be something like SU1000NET or SU1000. These generation UPS's require a sufficient battery voltage to be present in order to bring the UPS online. Which explains why it would see the BEST battery as the
"sufficient" charge temporarily, until the battery discharges immediately due to size. When was the last time that the battery within the UPS was replaced?
I really have no Idia but why dosent it work off of utility power i know it is recivint utily power but why doesent it work? i tryed to use it with the BEST battery still the Utlility Power dosent Power On...
Can i test it by wireing the Utility Power plug to the Battery Input Ternamals???
