Posted: 2021-06-29 05:54 AM . Last Modified: 2024-03-21 10:48 PM
I'm thinking of buying a QNAP ( [TS-412|http://www.qnap.com/es/pro_detail_feature.asp?p_id=193] ) or Synology ( [DS-411+|http://www.synology.com/us/products/DS411+/index.php] ) NAS and would like to add a UPS to protect it.
I think the APC Smart-UPS 1000VA 230V LCD could be the best for me but I have a doubt.
This UPS can switch off the PC and the NAS, both in case of prolonged power outage? via USB
Thanks and regards
how much runtime do you need? and do you want a rack or tower model? if you just need a little bit, i'd recommend SMT750 to start and use the USB cable to connect directly to the NAS.
you should probably check each NAS to see if it offers UPS support via USB and what the extent of the support is. I am only familiar with NetAPP devices with this documentation-> http://www.apcmedia.com/salestools/JMIS-6UULBJ_R0_EN.pdf
some other devices may be able to monitor the UPS via SNMP rather than USB. thus, you'd need a UPS with a network management card.
i did find this: http://www.synology.com/support/faq_show.php?q_id=300
i cant find too much on those links you provided. See if you can do a little more research on the specific products to see what they support.
Thansk i picKed a winna.
Finally, I bought the [QNAP NAS TS-419P9+|http://www.qnap.com/pro_detail_feature.asp?p_id=183] and I am now looking a UPS only for this NAS.
The NAStake 4 discs (each one with 2TB) [ ST2000DL003|http://www.seagate.com/ww/v/index.jsp?name=st2000dl003-bcuda-green-sata-6gb-2tb-hd&vgnextoid=add6439...]
Power Consumption
TS-419P+
Power Consumption (W)
Sleep mode: 13W
In operation: 31W
+(with 4 x 500GB HDD installed)+
ST2000DL003*
POWER
+12V start max current 2.0A+
Average idle power 4.5W
Average operating power 5.8W
The list of compatible UPS for the QNAP TS-419P+: [http://www.qnap.com/pro_compatibility_ups.asp]
I need one that can turn off
the
NAS
when
prolonged
outage
Any suggestions?
