84476members
353693posts
APC Home UPS switches to battery mode even though there is no power failure
goku_apc
971
This was originally posted on APC forums on 5/31/2013
I'm facing this strange problem for the last couple of months. All of a sudden my Home UPS 850 VA beeps 4 times and switches to battery mode and the battery LED lights up even though there is no power failure.
After few hours it switches back to main power but sometimes it never switches back to main power resulting in battery completely draining out and the UPS switches off.
I have to remove the mains power chord connected to the UPS and plug it into the power socket where the UPS is plugged to get the power back. Kindly help!
Model number: BI850SINE
Serial number: EB1143004463
Re: APC Home UPS switches to battery mode even though there is no power failure
This reply was originally posted by Angela on APC forums on 5/31/2013
How are you able to verify there is no power failure? Is the voltage displayed on the front panel anywhere? (We don't have these in North America so I am not sure).
I also found this:
goku_apc
This was originally posted on APC forums on 6/1/2013
I can verify there is no power failure by checking the mains switch which will be turned on but the UPS will be running in battery mode instead of running on mains power.
This reply was originally posted by Edward on APC forums on 6/17/2013
I have had similar problems with my UPS. One or two times a week my UPS would beep and PowerChute would warn me of a power loss. The computer would stay on battery power from 1 second to 15 minutes. I did not lose AC power. My lights did not even flicker. It has been doing this for years.
I mentioned the problem one time to APC support. They told me that it could be caused by voltage fluctuations or spikes. It was suggested that I go into PowerChute Configuration and set the Sensitivity to Medium. This has helped some but has not totally solved the problem.
Model: APC Back-UPS RS 800VA 120V Black (BR800BLK).
Nayeemulla_apc
This was originally posted on APC forums on 4/24/2017
Same poblem
Nayeemulla_apc
rudraapc_apc
This was originally posted on APC forums on 1/30/2018
me too facing the similar issue
KrazyKarvs_apc
This was originally posted on APC forums on 11/9/2018
Hi Arun,
Even I'm facing the same issue with my recently bought UPS.
Did you get any resolution for this?
8 Replies 8
goku_apc
I also found this:
goku_apc
Nayeemulla_apc
Same poblem
Nayeemulla_apc
rudraapc_apc
KrazyKarvs_apc
Hi Arun,
