F04 error in my apc pro1000 ups
Select a Country
  • F04 error in my apc pro1000 ups
BillP Leader
2150
147
83
Posted: ‎2021-06-28 06:50 AM . Last Modified: ‎2024-03-26 11:06 PM
43347
F04 error in apc pro1000 ups
BillP Leader
Leader
Here is a list of the codes for a Back-UPS Pro 1000 BR1000G
F01 On-Battery Overload Turn the Back-UPS off. Disconnect non-essential equipment from the Battery Backup outlets and the turn Back-UPS on. F02 On-Battery Output Short Turn the Back-UPS off. Disconnect non-essential equipment from the Battery Backup outlets and the turn Back-UPS on.
F03-F09 cannot be corrected by the user, contact Schneider Electric Technical Support for assistance.
F03 On-Battery Xcap Overload Faults
F04 Clamp Short
F05 Charge Fault
F06 Relay Welding
F07 Temperature
F08 Fan Fault
F09 Internal Fault
For F04 Clamp short the unit should be taken out of service and replaced. If the unit is under warranty please contact local support for assistance.
Here is a link to local support contact information. http://www.apc.com/us/en/support/contact-us/index.jsp You will need to change the country in the upper right of the web page to your region.
Replies 5
BillP Leader
Leader
What is the exact model and serial number of the Back-UPS? You will find the information on the bar code sticker on the back or bottom of the UPS.
Example
Hai...
Sorry sir......I don't see any serial....bar code..... Sticker removed.... Some one.....
Only model no.
Back-ups pro 1000
BillP Leader
Leader
F04 Clamp Short
F05 Charge Fault
F06 Relay Welding
F07 Temperature
F08 Fan Fault
F09 Internal Fault
Posted: ‎2022-12-20 01:00 AM
Disconnect non-essential equipment from the Battery Backup outlets and the turn Back-UPS on. F03-F09 cannot be corrected by the user, contact Schneider Electric Technical Support for assistance. For F04 Clamp short the unit should be taken out of service and replaced.
Rachel Gomez
Posted: ‎2022-12-20 05:01 AM . Last Modified: ‎2022-12-20 05:12 AM
Me too. F04 error APC Pro 900 model BR900GI. I did it.
3 defective relays. Check all relays.
I repaired the equipment just for fun.
If I knew how long it would take to repair the equipment, I would have bought another UPS. It took me 5 hours and 3 relays.
