Posted: 2021-06-29 08:31 AM . Last Modified: 2024-03-21 04:10 AM
I have an APC 750.
I have only two things plugged into the battery+surge outlets: The computer, which is plugged into the one marked "master", and my monitor.
The UPS battery is plugged directly into the wall outlet, however, the wall outlet is a GFCI outlet.
I had a lightening strike today, and everything shut down ... the monitor went out, and so did the computer. The green lights on the backup UPS appeared to go black for a moment, and then they came back on. (The computer and monitor are fine.)
First, do I have this all configured properly?
Second, is the GFCI outlet a problem? Is the GFCI taking the hit first, and then consequently knocking out power to the backup ups? I would think, if that was the case, the battery would continue to provide power to the PC and the monitor, which it did not in this case.
I should point out that I renovated my home office a month ago, and so I've moved things around, and I"m using new wall outlets. But, prior to the rennovation, this backup ups was working exactly as I expected. But now, it isn't, so I'm wondering what I've done differently to cause this.
ctm
if you have everything connected the same way currently and pull the UPS plug from the wall, does it support the load properly? that'd be my biggest question to help determine what could have caused the behavior you saw.
hello,
it sounds like things are plugged in properly..we also have this info on GFCI outlets: http://nam-en.apc.com/app/answers/detail/a_id/1344
So, if this all sounds properly setup, then do you have any good ideas why the backup battery would not supply power to the PC and the monitor during this incident?
ctm
