srt5kxlt indcates battery replacement. Replaced batteries and now says battery not connected. What gives?
Send InviteCancel
Posted: 2023-01-2006:50 AM
This happen to me now on three different units.
The lastest being a: srt5kxlt
Display indicated batteries needed to be replaced. Replaced with new "APC branded" batteries. Now the display says "Connect Battery"....... 😞 C'mon APC, you should have way better smarts in these things to tell us end users what the issue is. If replacement battery is not registering the correct output, then it should report that...... Can't keep dropping $$ on replacement batteries only to find out that the entire UPS needs to be replaced... So sad.....
