sc1000I battery probelm
  • sc1000I battery probelm
Posted: ‎2021-06-29 08:16 AM . Last Modified: ‎2024-03-12 03:10 AM
960
i face problem with UPS SC1000I ,i change battery but still see battery low and not carroy load for right run time only five min and diconnect please advise
Posted: ‎2021-06-29 08:17 AM . Last Modified: ‎2024-03-12 03:10 AM
ups take 24 hours to get full charge battery
Replies 7
I am not sure what you mean by "make test" - did you do the self test or a manual test but removing the AC power from the UPS and letting it run the battery down? A UPS self test does not last for a minute on the UPS as far as I know.
There also could be settings on this UPS potentially causing it to start indicating low battery. Do you have access to PowerChute with this UPS to verify what the low battery duration/signaling time is set to?
i make run time calibration by powerchute @ 300W load UPS give long beep and turn of
Since you're using using PowerChute it sounds like or some utility, how much runtime does the UPS report? And what are the shutdown settings on the UPS? I need to know the low battery duration/signaling time.
yes using power chute, when apply run time calibration @load 300W give 18 min but after one min UPS give continuous beep,in event log battery low
You'll want to make sure you let the UPS charge for at least 24 hours before doing any testing. You'll also want to make sure there are no serial or USB cables connected to the UPS when you do this. I assume you're removing AC power and letting the UPS run until it turns off completely?
How long were the previous batteries lastly? And what exact indicator do you mean by "battery low" - a solid or flashing LED perhaps?
