Posted: 2021-06-25 11:17 PM . Last Modified: 2024-03-19 03:15 AM
hi, i have apc BE600M1 replace new battery still not working and keep beeping i check the output not ac voltage
Have you reset the UPS?
1: Disconnect any attached load.
2: Unplug the UPS from the wall socket.
3: Disconnect the UPS' internal battery.
4: Push and hold the "On" button on the UPS for 5 seconds
5: Reconnect internal battery.
6: Plug UPS in to known good power source.
7: Turn UPS on.
If that does not resolve the issue you should contact local support. IF the unit is under warranty they will assist with a replacement.
Local support contact information will be found at this link.
https://www.apc.com/us/en/support/contact-us/index.jsp
You may need to change the region in the upper left of the contact us web page.
7: Turn UPS on.
