"Serial Port" failure
  • "Serial Port" failure
Posted: ‎2021-06-29 03:21 AM . Last Modified: ‎2024-03-13 02:56 AM
706
I nearly destroyed some incredibly expensive equipment because I plugged a straight-through serial cable into the back of an APC SmartUPS 2200 unit and connected it to a PC. Our experiment requires continuous power. The UPS shutdown immediately when the cable was connected between the UPS and the host computer! How is this a sane design?
I understand now that this DB9 isn't a simple serial port.
Suggestions:
Don't label something "Serial Port", and use a DB9 connector if it can cause an immediate and unexpected shutdowns in certain situations.
Place a warning sticker over the connector.
Something, anything!!!
I can't be the only one that made this potentially terrible mistake.
Janeway
Posted: ‎2021-06-29 03:21 AM . Last Modified: ‎2024-03-13 02:55 AM
You're definitely not alone. APC uses an RJ45 jack for the serial port on newer products. Plugging an ordinary Ethernet cable in will not cause a shutdown.
Janeway
