problem with security certificate
Showing results forΒ
Did you mean:Β
  • problem with security certificate
Posted: β€Ž2021-06-30 11:21 PM . Last Modified: β€Ž2024-03-06 03:18 AM
1261
i'm using powerchute business 9 (agent only) with one smart-ups SUA1000I
and i'm getting a certificate error every time i open powerchute.
i can continue by clicking "Continue to this website (not recommended)" ,but it is very annoying.
is there a workaround to this?
sytem is a i7 with windows7 ultimate 64-bit with internet explorer 9 RC 64-bit. (ie9 32-bit does the same)
i uninstalled and reinstalled powerchute but it didn't help.
certificate errors are also related to a wrong date/time but mine is ok.
Message was edited by: tdriver
i'll have to check. PCBE generates the cert based on the hostname of the server so it doesnt know what that is until it installs. does the browser let you install the certificate? i heard of a workaround with editing some keystore or something but i am not sure about how to do that.
Replies 5
πŸ™‚ happy to help
you gave me an idea thanks,
i manually installed a certificate in
"place all certificates store based on the type of certificate"
then
"select certificate store"
to
trusted root certificate authorities-->local computer
that's it.
i don't even need to enter the username and password anymore....great.
here all the steps for reference.
in the log on window:
right click->properties->certificates->install certificates->next->
manually
place all certificates in the following store->browse
"click" show physical stores
"select" trusted root certificate authorities-->local computer
"click" ok.
btw.
i need to enter the password again,but at least i fixed the original problem.
The progress on the electrical lines at the Fukushima Jeremy Scott Dai-ichi nuclear power plant was a welcome and Jeremy Scott Shoes significant advance Tuesday after days of setbacks. With the power lines connected, officials Jeremy Scott Shop hope to start up the overheated plant's crucial cooling system that was knocked out during the March 11 earthquake Jeremy Scott Adidas and tsunami that devastated Japan's northeast coast. Tokyo Electric Power Co. warned that workers still need to check all equipment Jeremy Scott Wings for damage first before switching the cooling system on to all the reactor units β€” a process that Jeremy Scott JS Wings ould take days or even weeks. Late Tuesday night, Tokyo Electric said lights went on in the central control room of Unit 3, but that doesn't mean power had been restored to the cooling system.
Β
